Originally posted by wheelnut
Engine transplant for a merc
Pfft, boring... L28 with a diesel crank etc for 3.1l, triple webers, maybe Nitrous kit :D That could be fun. Or L28 with L28ET stuff bolted on - also fun.Originally posted by blimpyboyAFAIK, the L-series and quite a few other early nissans were based on designs licenced from Mr Benz? To the point of some valvetrain components fitting right in. So no suprise that they are a reasonably straight swap, really, if a totally boring option floats your boat :pI've seen things you people wouldn't believe, and from this side only! The flight of a half-man, half-bird. Dinosaurs nuzzling their young in pastures where strip-malls should be. Cookies on dowels. All those moments lost in time; gone like eggs off a hooker's stomach. Time to die.
- Phil Ken Sebben
Originally posted by Gruntrosethe one getting around with the 13bt in it is certainly something different.
if its just going to be a "cruiser" as such... does it really need a transplant? unless its ridiculously cheap, it would be easier to buy a newer model merc, still "pimp" it up and have a v8 engine in it already?
Naturally-aspirated 20B with Peripheral port setup ...:D different. :D
mercs have a weirdo engine bay that often means wide V8's simply won't fit. go over it 20 times with a tape measure before choosing an engine.Turns out, far too much has been written about great men and not nearly enough about morons
Keep it German, Porsche turbo
― Jim C. Hines
― Daniel Patrick Moynihan
― Napoleon Bonaparte
they put the numbers on upside down LOLOLOL11!1internetTurns out, far too much has been written about great men and not nearly enough about morons
Be Careful with the Rod shop conversion also, Mate bougtht the rod shop conversion for his '69 merc and had all sort of issues fitting it, ended up needing lots of mill work. to bring the engine back down to a more manageable height.
The rod shop conversion sat the engine way too high, with carby etc protruding through thugh bonnet by a long way.
hi, hows this project getting on?Turns out, far too much has been written about great men and not nearly enough about morons
1UZ's are pretty small though, at least my mates one looks to be. Certainly not in the same ballpark as the new Ford 5.4's, those things are beh-hweemoths!Originally posted by Secoh View Postmercs have a weirdo engine bay that often means wide V8's simply won't fit. go over it 20 times with a tape measure before choosing an engine.Originally posted by klampykixxas an example, an elephant pushes over a tree to eat the fresh leaves at the top, but a human isnt allowed to build a machine that makes a car so he can drive around to places quicker?
