what to look for when buying a S1 VT wagon
    Originally posted by SHEEL
    My dad has a series 1 and has HUGE issues with rear tyre wear. too much neg camber on the irs especially when towing.
    I'd say keep saving and get a VX s2.
    and Bugle, I've seen rust on a vp and a vr commode inside they door jambs. and a vr aint too old either! So I wouldn't assume they can't rust...
    Yeah I do look for rust, one problem it's got starting now is similar to a Gemini problem. Where the rear beaver joins the rear guard above the tail light the seam sealant has cracked and let abit of water in starting rust lucky I spotted that. I'm also a bit concerned about the rubber strips in the roof eventually hiding rust underneath them..
    Mine doesn't have much problems with tyre wear even though it's got 3 degrees neg camber on the rear but it doesn't do any towing.
    as short as possible
      Have you checked out
      http://www.pickles.com.au/servlet/Au...sale=452000221
      Seems to be a few wagons up although not as cheap as the VT
      http://www.pt.qld.gov.au/pubs/docs/motor/061006zlm.pdf
      Maybe QFleet as well.
        Wow... considering I was going down this same route maybe I'll hold out for a VX too
        VX S1 better with the tyres than the VT's? or S2?
        Would the rear tyre wear be a problem on them if not lowered? I plan on towing with it but the bike only weighs 10/10ths of fuck all
        Are these problems wagon related or just general VT problems? (rear tyre wear wise)
        Insert random question about me wanting to know how to make a wagon handle?
        Speed cameras: Best tax ever! The one that makes you pay and makes you think you deserve it.
          The extra link they added is just for toe, isn't the tyre wear issue caused by camber?
          No wait tyre wear would be caused by toe as well if the car is lowered or carrying alot of shit. At standard ride height my one has both rear wheels parallel..
          So if you're carrying heavy stuff in a VX2 it's gonna have lots of camber but no toe out/in?
            I think the IRS tyre wear thing varied from car-to-car; our VS sedan seems fine, but it's probably carrying less weight in the rump (despite the highly aerodynamic spoiler probably putting tonnes of downforce on the tail at 80km/h).
              The old's VT didn't suffer TOO badly from rear tyre wear, although sometimes it did have an awful lot of junk in the trunk. Mind you, when I drove it I made it suffer. Used to be very controllable in a slide, as long as you didn't get out of the throttle in a big way.
              as an example, an elephant pushes over a tree to eat the fresh leaves at the top, but a human isnt allowed to build a machine that makes a car so he can drive around to places quicker?
                i thikn burnouts will wear the tires more then the camber.. lol
                haha, nah seriously, if its to low and to much camber u can just get it fixed up so its low and the correct camber
                i know i had to do the same with my silvia
                Originally posted by Lobster
                  Don't buy anything that once belonged to Morgs.
                    is it wise to buy the S1 of anything?
                    I would have thought it's a better idea to get a S2 where they have fixed all the little bugs in the S1?
                      Or that Rorge is interested in buying.
                        What would happen if Rorge bought a car off Morgs?
                          i dont even want to think about it
                            Yeh I tend to agree with that.
                            Ride : Turbo LPG Gemini - http://www.ozgemini.com/forums/non-t...hp?f=6&t=25363
                              I regularly service a VT S2 wagon.It has done 360K and rarely uses a drop of oil,just a little before service is due..
                              Things to check i'm surprised no one has mentioned is power steering pump leaks and check auto transmission oil is nice and red and not burnt or there is $$$$..
                                Originally posted by ironhorse
                                he is talking about a VT not an XF /EA /VN .
                                haha you dont live in townsville
                                a metrosexual is only a virgin homosexual.
