Where can I get a plug like this?
    So it turns out that the TPS and associated wiring on my Impreza is dodgy. TPS is simple enough to replace but the wiring coming out of the plug for it is damaged right up close to the plug. Unfortunately the Liberty I got for parts has a different plug so I can't rob it. What's the easiest/best fix for this? Do I try to get a piece of wiring loom off the wreckers with the plug attached and splice it into the existing wiring (soldered and heatshrinked) or do I buy a new plug from somewhere? I'm guessing I'd need some fancy crimping tool if I did the latter.
    sorry about the poor pics, camera phone and no glasses.
    Mick
    Have a look at http://www.bmotorsports.com/shop/
      Pull the plug apart to remove the pins with wire attached, heatshring the wire and reassemble.
      PM me for more info
