Fuse & Relay Mounts
    Fuse & Relay Mounts
    Guys,
    I'm looking to fit a new ECU to my 510 in the coming months and i'm just planning it out. I want to use a decent quality, OEM looking fuse/relay holder to mount it all up. I want something that is completely self contained for both relays and fuses. (kind of like the new haltech one)
    So far I have found these. They come in around $90/$100 USD shipped with all terminals etc.
    I need 4-5 relays and 4-5 fuses .
    Any other suggestions?
    That Bussman unit is super nice, why not get that?
      Just exploring my options
        If your a massive tightarse, vn-vs relay boxes are good. Im fairly sure they are modular, so you can add/subtract to suit yourself. Iirc they had fuses in them too?
          so that thing comes pre wired with pos/neg bus bars and shit? niiiice
            is the gauge of wiring in the busman one sufficient?
            i know the power and ground running through my supras standard fuse box are a much thicker gauge...
            does look a quality unit though...
              Haltech have one now, 6 or 7 relays and fuses, you have to wire it all your self..
              I'll get pics in the morning if your keen
                awesome thanks dale
                  The Bussman stuff is available through Flexible Drive Agencies it is very good quality gear.
                  PM me for more info
                    Dale, did you ever get a pic of this fuse box?
                      I have just come across this unit:
                      http://www.ebay.com.au/itm/4-Way-Spl...ht_2041wt_1397
                      mounts with this unit:
                      http://www.ebay.com.au/itm/16-Way-Ci...ht_2019wt_1397
                      Given though i only need the relay mounts i think ill just pick one up. Anyone get them in Aus before i buy from the UK?
