Regulated 5V power supply
    Hi,
    I am looking at powering two in car cameras from the electrical system of the car rather than internal batteries. Only issues is they are 5V devices (USB spec). So, what options are there, what do people do to provide regulated 5V power? I was trying to stay away from cigarette style adapters as well.
    This is in a rally car.
    Thanks
    Paul
    A couple of DC-DC regulated converters should do the trick.
    9~36V input 5V regulated output. Up to 0.6A load.
    Jaycar/Altronics should stock these.
      Most small electronic devices use a 1A supply.
      Go Pro recommend a 1A charger when recording but state anything between 500mA and 1A is suitable
      Edit - Would be worth checking on the vibration and heat specs on any package.
        LM7805 regulator with a small heatsink, vry cheap and easy enough to solder in.
        PM me for more info
          As Glenno says, use one of these for each camera. http://www.jaycar.com.au/productView.asp?ID=ZV1505
          If you really want to get carried away, add a capacitor and inductor but I personally wouldn't bother!
          cheers
          Gaz
          www.vsport.com.au
            cheers
            Gaz
            Camera gear will have it's own filtering so not worth the drama.
            PM me for more info
              Thanks for that guys, I'll go to jaycar tomorrow arvo and get some.
              Paul
                7805's are ok. They chew the current a bit though! Jaycar has a new heavy duty version that's 1 amp or better don't remember the part # right now but the counter nerd should.
                If your on a slim current budget then a cheap cig lighter-usb charger (possibly from jaycar) could be gutted for its board is quite small and most supply an amp or 2 with much better efficiency. This board could mount up under your dash and wire it to sockets (an old usb hub or another visit to jaycar).
                  Went to Jaycar, nerd behind the counter was useless, end result 5 7805's on my desk with heat sinks sitting next to them.
                  Just waiting on a wire delivery now.
                    Bit late but would a Cheap little incar 12volt to 240volt inverter running a computer power supply work. They output 12 and 5v dc I think.
                    Originally posted by E-Z
                      Get one, pull it apart - they're easy to strip, then hardwire it in. easy.
                      GT-P
                      Bandsenkowagon
                        Read post #6 on this thread on VFR Discussions for suggestions.
                          If you are pulling 1A at 5V via a 7805 running from 12V+ you'll be generating a shitload of heat because it's just a linear regulator. 7W is a lot to get rid of. 7805s don't really "chew any current".
                          If USB what about this?
                          http://www.jaycar.com.au/productView...r&form=KEYWORD
