Footwell Lighting
    Footwell Lighting
    Ok.
    So I want to install some footwell lighting activated with the interior light for both the front seat passengers, and some mounted under the front seats for the rear passengers.
    Install is done
    But, My problem is hooking into the door jam interior light switch.
    There is only one wire coming out the back of it.
    It is live (+) when door is closed, and has no power when door is open, which is the reverse of what I want, and the reverse of how the interior light operates.
    Where should I be hooking these footwell lights Positive and earth wires?
    2013 Opel Insignia OPC
    2013 Kia Rio
    2018 LDV T60
    Generally the ground is an earth, so when the door is open it earths and completes the circuit.
    In that case you wire +ve to permanent 12v and the earth to the door switch.
      Cool thanks, I was going to try that, but found it strange that the door switch wire i'll be earthing to has power already?
      2013 Kia Rio
      2018 LDV T60
        you will always have power on one side of a switch, in this case its going battery -> light -> door switch -> ground/earth. Much the same as the bonnet switches used on car alarms
          What car? Might already have wiring inplace.
          For my VS I just tapped off the wire leading to the interior light up the driver's A pillar.
            R32 GTR
            All done now, wired as per above advice.....just did'nt seem to make sense at the time (wiring lights earth into something that had power)
            2013 Kia Rio
            2018 LDV T60
              R32 GTR
              It would measure 12v with a multimeter, but as soon as you try and draw a decent amount of current off it, it would drop dramatically because it's going through a relay or globe .
