battery lug crimpers
    Anyone have this style of battery lug crimpers? Good? Bad? This version, 6-50mm2 is about $25 on eBay.
    Are the hydraulic versions better?
    I have this. It is tits.
    http://www.rhinotools.com.au/hydraul...e-crimper.html
      I have the manual type from 6mm to 120mm and does the job easy. Been meaning to get a set smaller as its bit of overkill for the work I do now. Anything bigger than 95mm warrants the effort in using a hydraulic or pneumatic crimper.
        Originally posted by myshortyboomba View Post
        Those hydraulic ones are unbeatable for the price!!
        Breaking stuff once is ignorance, twice is stupidity, three times is racing
        http://www.performanceforums.com/for...chev-LS1-turbo
        http://www.performanceforums.com/for...tchback-torana
        http://performanceforums.com/forums/...ghlight=ari300
        http://performanceforums.com/forums/...Dog-Piston-rx4
          I have the hydraulic one above. It is excellent and does very good crimping.
          Originally posted by Einstein
            How quick are the hydraulic ones? BTW Jaycar have the smaller crimpers (up to 50mm sq) for around $50.00.
              hydraulic is good for multiple large crimps but for the odd battery cable the manual type in the OP are fine, the only time its a pain in the arse is trying to crimp in situ with bugger all room, i have both types and usually just use the manual because its quicker and not as heavy (pretty much a 2 man job trying to crimp 3 sets of 300mm^2 mains inside a panel and with proper big cables you wouldnt bother with the manual crimpers)
              if you want to crimp a bunch of lugs a bunch of times the battery powered crimper is awesome.
                Ive been using a big hammer and whatever is handy with a bit of an edge on it. Seems to work a charm so far.
                  Yeh, for a one off job it would not be hard to make up two semicircular 'dies' with one to grab in a vice and the other long enough to belt with a hammer.
                  ― Jim C. Hines
                  ― Daniel Patrick Moynihan
                  ― Napoleon Bonaparte
                    I used to do that. and it was ok.
                    Then I started using a vice. it was better.
                    Then I bought the above crimpers. they are much better.
                      I have a similar ebay hydraulic one as posted above.
                      Much awesome. Fairly quick to use.
                      I have DOHV & pushrods, i go very fast. Now going much faster with TypeR power.
                        iHaz the cabac version of the above hydraulic crimpers.. Fucken handy
                          I use a swaging tool I bought from bunnings for about $40. I initially bought it for - wait for it - swaging fittings on trailer brake cables, but now have a million uses for it.
                          Basically looks like bolt cutters, but instead of a blade it has a crimping end. Kinda like this:
                          Originally posted by 350stato
                          100% agree with Shifty
