Incar 12-240V inverters. What's the hotness?
    Thinking about getting an inverter for the kids DVD players/charging kids's games, nopics' Mac etc. Any recommendations?
    Also is it an issue if it's plugged into the accessory socket? Provided the socket is rated high enough naturally, must check that actually.
    ive had a yum cha 600watt one from dicksmith for years. never skipped a beat.
    as your well aware, most cig lighters are limited to 5-10A. which will limit your over all consumption unless you hard wire it.
    so look at the wattage on all your gear and work it out from there. cant see any of the above being too much of an issue. just dont run fridges/microwaves of it obviously. oh and they get hot, so put it away from prying fingers/well ventilated area.
      Make sure you know if the accessory socket is switched. Sometimes they can be always powered so easy to run the whole thing flat. Aside from that and the rating which you've noted they are not different.
        Checked the power rating for the accessory sockets and the manual only lists the front one @120w, I'm actually assuming that might be for both front and rear sockets though. Will have to do a bit more digging to find out exactly, namely try and match up the fuse listing in the manual for the 4 fuse boxes in the damm car. Been caught out by the constant power accessory socket before, the Voyager's rear socket was constant power yet the 2 front ones were ign switched. Lucky for me Citroen has low voltage protection which shuts everything down when required.
          it will be 10a.. 12v*10a=120w.. i think thats the math behind it?
            you could always run you own 2 core, say 20/30amp wiring back to one of the plugs, disconnect original wiring and plug in your own. shouldnt take more than an hour or 2 to do, and tuck away out of sight.
              Yes that's the maths. Make sure you're comparing the input current or power to the inverter though, not the output power of the inverter since it will not be 100% efficient.
              Also the fuse will probably be rated a bit higher than the 10A particularly if shared with other circuits.
                Yep, that's it. Doesn't seem like much headroom though, nopics ran a car kettle in her Colt and I'm pretty sure that pulls more then 10a.
                That's another option, although I'd avoid touching the OE stuff and run http://www.waeco.com.au/products5.as...subCatId2=127#. Probably will do that anyway just for piece of mind really, dad uses them in both his Escape and Challenger.
                The 120w is what is printed in the car manual. Hence me not sure if it's per socket or combined. If combined I then have to figure out it's just the cig style sockets or includes the USB sockets as well, which I've only got one although apparently upto 3 are possible. More I think about it, the more then Waeco thing above makes sense.
