Electric Power Steering - wire size
    Adding electric PS to the project car so I need to know what size power wire it needs. Thinking of powering it directly from battery via the master switch via a 50 amp fuse and activating it from accessories Have been told that these suckers draw a lot of current.
    Which electric power steering motor/pump are you using?
    As a start the factory fuse and wiring size is usually a good start.
      What column did you use and how much work is it to fit up ?
      List of cars goes here
        Ford, Mazda and Volvo electrohydraulics pull up to 80A full load and are fused at that.
