Car speakers - whats the shizzle.
    So's whilst fiddling my stereo I forgot I had the 6.5" front and rear speakers were on "full" mode on the amp instead of high pass and the Blaupunkt's are now dead, they sounded great but yeah.... gunna buy something else.
    What decent in the 6.5" component deals for around the $300 mark, am not a brand snob so am open to all suggestions.
    FWIW the amp is a 4ch MB Quart but its a baby at 60w RMS per channel, it is getting the flick in favour of something with some balls.
    One set of speakers hat does tick boxes for me is the Massive Audio FZ6 speakers.... but can find very little about them on the googles which has me shy.
    https://www.massiveaudio.com/collect...onent-speakers
    Morels are good bang for your buck.
      Morels not available here/readily available.
        Unless your'e building a competition audio setup, 60W RMS per channel is HEAPS for 99% of listeners, and thats probably why your current speakers arent happy anymore.
        Do you have a sub as well? That makes it so much easier to set up your HPF/LPF crossover points. Which head unit are you using btw?
          Its a work in progress but has a Seicane 9" android head unit feeding into an A/D/S DSP and a couple of 10" subs.
            Hahaha...so not a typical set up then
            Are those subs inside their own enclosure or running in free air?
              Internal sealed 1cu.ft boxes each, that whole lot went to trash today..... I have 4 of those subs so changing it up.
              Purchased a 3 way set of Focals for the front......need to sort an amp.
              https://www.focal.com/en/technical-s...kits/ps-165-f3
                Have Focal 3 ways up front in my 86, might not be that exact model but they would be the equivalent of them ~5 years ago when I did the install. They kept up with 2 Fusion powerplant 12's in a ported box that took up the entire boot/rear seat. I think you'll be happy with them.
                  Cheers, hope so !!
                  Might be one for the what pisses you off thread next weekend but the mid will go into flat area of the door trim,I prolly shoulda pulled the trim and checked how much room there is to the door glass but if they wont go there I will buy the equivalent in the Focal 2 way components and put these in the new box in the back.
                    I've got 8" focal splits in the Q7. I'm no audiophile but they were a massive improvement on the factory shit.
                      I went with Rainbow Germanium 2 way splits some years ago. Love em still.
                      PF Gamers List
                        Automotive Superstore currently have a Special on Speakers...
                        https://automotivesuperstore.com.au/...-direction/asc
                        Might be worth hitting up kabab
                          would love to support an AUS/PF store but alas...they cannot ship international.
                            Have you messaged kabab ??
                            He may be able to help directly for a PF'er
                              Yes.
