Micro relay fittings - where to get?
    I've fitted a light bar to the new CX8, but the plug and play options that came in the kit to trigger the light bar relay didn't fit. The easiest access point to wire the relay which doesn't involve hacking into the loom is the fuse box, which includes a bunch of micro relays. I've got the light bar working using the dodgy test loom you see in the picture below, and I want to make up something permanent. Does anyone know where I could get male and female fittings to go between the fuse board and the relay? Thanks.
    https://imgur.com/a/xOi0wwl
    To clarify, I'm after the male side of this:
    https://www.repco.com.au/en/globes-b...6bl/p/A9263675
      Notionally they’re 4.8mm spade lugs for the “trigger” and 6.3mm for the current.
      I was pretty sure Jaycar sold them as bare items but I haven’t checked for ages.
        THanks I've got a Jaycar nearby I'll drop in and ask.
          https://www.jaycar.com.au/search?text=male+spade
          Just make sure of the width you need.
            I've resigned myself that I won't get the male fittings, so went to Jaycar got the spade connectors and will make the fitting out of potting compound or epoxy putty
