Motorbike motors into cars? Can it be done legally in nsw?
    As the title says, interested in the legality of putting a bike motor into a small car? Anyone in the know?
    An example of a datsun rally car in NZ (no I won't be chopping a firewall)
    No, can't be done due to the emissions regs.
    Though I guess if you were willing to spend enough to prove it passed the requirements it might be possible.
      I thought they'd got 2nd gen Busa motors approved?
        Not AFAIK.
        The Clubbies use them but only for the track. It's a shame as a 'Busa-engined one would be a good thing I reckon.
          I dont get it
          if the engine passed emissions in the bike and all you do is swap the engine from bike to car why would the emissions be an issue
          unless its a new car the engine is going into
          List of cars goes here
            I think bike emissions requirements must be really low, otherwise how would carbed motors still pass?
              Originally posted by Gassed250 View Post
              I dont get it
              Bikes don't have to pass emissions.
                yep cheers just figured that out
                http://www.oz-clubbies.com/forums/lo...php/t6137.html
                http://www.oz-clubbies.com/forums/in...=5035&hl=IM240
                  you could do it provided you get emissions tests passed.
                  then they may make up some other shit to stop it passing.
                  you still have to mount it to a box that will handle the tractive efforet due to 2 tyres instead of one. and get a drive shaft setup.
                  RNJ Fabrication
                  Design-Machining-Welding
                  RNJfabrication@yahoo.com
                  04 0737 0736
                    http://www.wikiwirral.co.uk/forums/u..._CBR900_R.html
                      You're overthinking it - there are plenty of examples of bike engined cars getting round with the integral gearbox, and it's surprisingly easy to set up a driveshaft on them.
                        there was an escort on jewtube with a turbo fairyblade donk in it. sort of went ok.it looks like win to me. they'd just adapted a driveshaft onto the countershaft of the bike 'box.
                        Originally posted by Skompa
                          http://www.miatabusa.com/
                            mate checkout hyabusa smart car on youtube they are crazy
                              Never seen an Aussie Race Car with the body removed??
                              Tailshaft bolted to the drive sprocket/offset rear diff/live axle setup.
                              [ or offset the motor to get a central tailshaft.]
