New Technical Section Rules - Please Read
This is a sticky topic.
    Please note the new rules for the Technical sections. Moderation will be stricter than in the past, and if you don't obey the rules expect to be moderated!
    Your new moderators for this section are: Bigmuz, Cal, Pol Pot
    The technical sections (and all subsections) is for technical discussion only over a number of areas. This section will have tighter moderation than the offtopic sections and is not there for people prove their e-ego or slag off others. Any of these actions will result in moderation. The following rules apply:
    • Keep it to serious technical discussion only. No stupid comments. Stupid comments will get you blocked from this section.
    • Not everybody will agree on all things at all times. Back up any statements with factual arguments, and not ill-conceived one liners.
    • No personal attacks are allowed - you can rib people to an extent, but soon as you start calling them a fuckhead or a wanker, then you've probably crossed the line.
    • If you don't like what a person is saying, at least use some tact when pointing this out, and use some common sense in pointing out your difference of opinion.
    • Not everybody can afford an expensive car, or has $50k to throw at modifying a car. Respect that fact, and don't belittle others for not being as well off as yourself.
    • No porn or NSFW content is allowed in this section and it should remain work friendly.
    For those that breach the rules the following will occur:
    1/ Mods will edit or delete the offending post(s) and explain why they did.
    2/ Second warning
    3/ Banned from the technical sections for 1 week
    4/ Continued wankery - banned from the car corner section for 1 month
    5/ You're always a cunt in there - perma ban from these section(s)
    If you take an offence to a post, or need some action, take it up with a PM to the moderators above. If you aren't happy with the moderator action, take it up with Billzilla or the new primary admin (centrelink)
    RIP Simon - Ghost ride that whip in the clouds forever..
