Car is an 08 D40 Navara with no motor. So PF brains trust, I am looking for advice for a project I have started collecting gear for.
The need is for V8 goodness with tough auto box for towing horse float and weekend fun duties and have decided on a 4L80e and GM NP241 transfer case which has same side drop as the Navara front diff. this part is not really of any concern other than stall type and speed.
The engine is the part that concerns me. It must be daily drivable with bulk torque. I want it to feel like its going to pull you through the seats when I hit the loud pedal. but drive stock like when not playing the fool.
I have an LS1, it is complete and free so my plan was to build a 383. 4.00 inch Lunati crank, 6.125 rods and CP Carillo or JE forged pistons to have a compression ratio of 10.5:1. Heads will have a CNC port job and stock valves, LS6 manifold, 92mm throttle body. (bottom end is WAY overkill, however if the boost itch bites, it will be strong)
How does this package look for drivability, power, torque and reliability?
Cam spec suggestions?
Any advice, for more or less anything to achieve the goals outlined.
Sorry for the novel:knock:
