Crazy cheap and plenty of grunt.
D40 Navara 4x4 with LS1 383 stroker+4L80e
Originally posted by BRK50 View PostBuilt with upgraded internals and mild shift kit can handle 600+hp with ease.
Edit - jesus fuck those LSAs are cheap now, how much on top for a loom and computer to run the show?
Have been flat with work and a change of plan has unfolded, as always.
I brought a LS3 from a wreck after. Deciding building a stroker on an old motor was a drama. I have a TR6060 VE 6 speedto offload and I'm torn between the 4l80e and 6L80e.
I need a loom custom made and I'm working out the path of least resistance. I'm thinking 6L80E with custom loom, to suit, and matching ECU an throttle pedal from the car I get the 6l80e from.
Please fire away, I'm unclear at this stage to the smoothest path to make everything communicate?
Originally posted by dogsballs View PostKeep manual
It's hard to get a definitive answer whether a corvette tail housing from a t56 will fit. If it does I can have a adapter an spline coupler made for happy clutch dropping fun.
