LS1 or LS2/L98 into 63 Belair
    DOD delete in with the Cam swap
    Originally posted by cheapracer
    Sperm are clever little fuckers that got us where we are today. You've never heard of pre-cum by the way?
    Originally posted by Nugs
    That's why I punch myself in the nuts before sex, get them disorientated.
      Yep fuck the DOD off - at 140,000 I'd give it a birthday before putting it in anyway
      There's now 2 running 64's on PF with the 6L80E in them... I've only done ~50km in mine so far sorting a couple of teething issues with the new brake setup but no clearance issues with the bigger box at all, definitely put it all in!
      Originally posted by race6.3l
      Only gripes are the bluetooth and stereo are bread and butter spec, not one person has been able to hear me properly during a call, even with my head all contorted towards the roof mounted microphone like im trying to growl a chic sitting on a clothesline
        Thinking of getting it running and enjoying the thing for a bit before a birthday. Its been almost as long in the making as yours.
        What suggestions for the birthday?
          So its a L76 and as mentioned, it has the AFM. I am not planning on running with the DOD and cam this time round.
          I know I need a rear sump to clear the cross member and that there are plenty available.
          My issue, a mate told me that the L76 with the AFM runs a different sump and pump due to the AFM.
          Can anyone shed some light on this and what sump would work?
            Lies. Just need to plug oil towers at top and run any valley plate, ls7 lifters
            Originally posted by 50RTD
              Thanks Mr. Balls.
              But that does not mean much to me. Can you elaborate
                AFM sump has a oil pressure relief valve for the DOD doesn't it?
                  L76 doesnt have it activated though. Will have collapsible lifter but rest isnt there. Any rear sump will work
                    How can I be sure that the AFM isn't activated? Fucking AFM badges all over the ute so just assumed it would be running or Holden wouldn't say it was.
                      L77 or L98 had it activated.
                      You are stressing over very little. Sump is $150, new cam $500, ls7 lifter $200, valve springs $200. Dalecunt remote tune, few hundred kw bulk?smiles
                        This is the kit you want, sits perfectly over the cross member without hanging too low, just check it works with your mounts
                        http://www.ebay.com/itm/Chevrolet-Pe...7/252859153171
                          dont fuck around, take it all out... put the same cam as ITS60s and it it has a nice idle with out being over the top etc
                            What cam is that?
                              What cam is that?
                              stage 3
                                Oztrack 1/3 racecam
