3uz fe, Lexus v8
    3uz fe, Lexus v8
    People talk to me about these motors!! Can I get a front sump version. Seem very wide. What are the 6 speed autos like?!
    Am I in for a world of pain?!
    Originally posted by 50RTD
    what in and what do you want to do with it.
      Vl, 9s drag car, all under bonnet, stealth single or twin turbo
        Start with an early 1uz with big rods and add head studs and gaskets and valve springs. sorted.
          My 300,000km 1uz makes 400rwhp through a glide/converter on 13psi unopened.
          Super quiet and even runs a cat.
            you could do all that with an rb30/ barra or ls something.
              boring
              caprice nugget.
                ^ this guy
                  3UZ probs not a great start. An old 1UZ is the easiest to get cams etc for.
                    Can you do eflex with methanol?
                    Could be fun.
                    Mmmmmmmmm beer.
                    Originally posted by ALLMTR
                      Put an LSanything in. It'll be $15k cheaper.
                        Unfortunately this.
                          I agree with Rdyno
                            For a 9sec drag car go LS... (give me the 3UZ)
                            if you're set on a UZ... 3UZ is good if you intend to do pistons and rods anyway, in theory (according to some toyota docs) it's the stiffest UZ block they made with partially siamesed bores...
                            6 speed auto is a good thing, I have not wired it to the PCS TCM-2000 yet but will at some stage... uses same valve body as landcruiser 6 speed if you need beefier box..
                              Generally agree on LS (especially just coming back from drag week) but UZ still offers absolutely decent bang for buck provided you can keep your your goals clearly defined (ie, don't set out to build an 9 sec car and then decide you want to run 8s)
                              As above my totally stock high km UZ runs 400rwhp through a glide (toyota auto add another 50rwhp but lols at spending any money on an A340) - have done a couple of thousand kms on this setup = no issues. Add $1000 in parts (head studs, cometic gaskets & springs) and it'll comfortably run high 400's rwhp all day on stock bottom end with a glide = easy high 9s in a VL.
                              Shit gets expensive super quickly once you go chasing big numbers or dont get the combo right (turbo, cooling system, ecu, trans). UZ IMO is all about cheap fun with something a bit different, want anything more than the above UZ is not for you.
