Talk to me about 4JJ1 conversions
    Because it is infinitely more capable than a 2F with a 4sp box behind it, they are relatively accessible engines and dont cost stupid money like HD or FZs, and not requiring silly amounts of modification to fit like a Duratec or Cummins.
    ok. that makes sense. a lot more room at the front of the engine for a decent cooling package too.
    Originally posted by Skompa
      Look into TF Rodeo 4JB1 or Jackaroo 4JG2 gearbox and transfer cases. Im pretty sure they were all bolt-ups to the 4JJ1 with a bit of fiddling around with clutch forks and clutch slaves. Manually selected transfer cases so no need for wiring headfuckery to try and get the 4WD to work[ RA 4JH1, RA7/RC/Dmax 4JJ1 are all electronic selection]. Person you want to speak to is Clayto on the Jackaroo and 4JJ1 Conversions facebook pages.
      Cant remember if 4JH1 TF and 4JX1 Jackaroo were still manual-style transfer cases
      1978 Gemini Sedan - Powered by i change my mind every week - R.I.P
      1980 Gemini Sedan
      1987 Range Rover Vogue
      1996 TF Holden Rodeo
        Ah, thanks for that. I had figured we would be programming a microcontroller for the 4WD system solenoids, but if a Rodeo or Jackaroo gearbox bolts up then that simplifies things a lot, they are driver's side drop as well, so that makes things easier too, can end up getting a later model engine and using that gearbox for drop.
          Quick search on the 4JJ1 Engine Conversions FB page says the hotness is using the DMax/RC/RA7 box with the Jackaroo manual [ie not later shift on the fly] transfer case bolted up to it. The man you want to annoy is Clayton Spencer.
          1980 Gemini Sedan
            Reaper Performance Diesel have taken a slightly different approach to re homing a 4JJ1 + T56 ....
            https://www.facebook.com/ReaperPerfo...96806675269704
              https://fb.watch/8oRzcK-rZU/
              One of Reapers other efforts....550rwhp on a standard bottom end is stout in any language, let alone when it's a 3L Diesel
              1980 Gemini Sedan
