Ford Ranger 6R80 6-speed auto & transfer case bolts up to _______ ?
    Maybe somebody knows this already....
    Are there any modern Ford 4-cylinder turbo petrol motors that would bolt straight up to the 6R80 6-speed auto from a PX or PX2 Ranger?
    Basically looking for a modern 4WD driveline to put in an old Land Rover, and the idea of a Ranger as a donor springs to mind.
    But there's always a catch, the guy doesn't want diesel. So the 2.2 or 3.2 Ranger diesels won't make the cut.
    And a turbo inline 4 makes the most sense from a packaging perspective, so V6's and V8's are out.
    Haltech can run the TCM in the Ford 6R80 box (so i'm told) and the Ranger transfer case is a fairly dumb thing compared to the late model LR ones so shouldn't be too hard to make work.
    Just need a suitable turbo 4-banger, Duratec, Ecoboost, Zetec, WTF
    It'd be nice if a 2.0L Ecoboost from a Falcon just bolted straight up, pics I can find online they look like a similar bellhousing to the 2.2L diesel...
    Originally posted by nutttr
    PK or PX?
      Derp, I meant PX or PX2
        Pretty sure the Mustang 2.3 ecoboost was bolted to the 6R80 box.
        Think the Coyote was too.
          Ecoboost has two different bellhousings. One that’s shared with Duratecs (and the Mazda cousins) and one that’s very similar but not quite the same. I’m ignoring the <2.0 Ecoboosts and Duratecs - they’re a Zetec pattern.
          I am pretty sure the Diesel and the Duratec housings are very close, there was a Transit van manual that some mob was screwing to Ecoboosts and selling turnkey manual RWD setups.
            Cheers kents, but we probably have to go back to the drawing board now, I just realised that the PX Ranger has the forward propshaft on the left, would need it on the right otherwise the front diff of the Landy would have to be changed too...
              Can prolly get CAD of the Ranger bell housing mounting face if that helps.... Assuming manual and auto are the same.
              Guy who bought my old Ranger (dead engine) bolted an LS1 to the Ranger 6 speed with an adaptor he CAD'd up and had made.
                Matching diff ratios?
                  Diff ratios is further down the list of problems.
                  Bigger issue is that the LR front diff has the centre/pinion offset to the drivers side.
Name:	Screen Shot 10-17-21 at 08.11 AM.JPG
                  PX Ranger has the forward driveshaft running down the passenger side, so would need a completely different front axle to go that way...
                  My old man has a PK Ranger, and I remembered the driveshaft was on the drivers side, I assumed the PX would be the same, but I was wrong...
                    With the amount of effort you’re going to just put a Land Rover body onto a PX chassis. Then you’ll even have brakes that work
                      Mustang Ecoboost apparently uses the 6R80.
                        Isn't the rear diff offset also, or are you changing the rear axle assembly to a centrally located housing? But like lukevl says, it looks like a massive effort.
                        Wouldn't something in front of a LR LT230 transfer case be easier? Like a ZF auto from a Discovery?
                          You make it sound so simple!
                          Right but I had a suspicion that there were different bellhousings as in not all 6R80's are the same, and the idea of the Ranger one having a transfer case already on it would have made it easier, not that it matters now...
                          That's also true... but rear axle would be less of a head fuck than the front....
                          Thought crossed my mind but the ZF 4HP's are really old and shit now, so there'd be $$$$ in rebuilding them, and then it's still a matter of adapting to a modern 4cyl at the front end.
                          The idea of a Ford parts-bin approach was appealing because the Rangers are stacked six-high at the wreckers, likewise the 2.0L Ecoboosts.
                          Rebuilding old Land Rover shit is not cheap, and at the end of the day it's still old Land Rover shit. The guy is looking for a modern driveline.
                            You would never get it registered.
                              There’s always a way. And sometimes its legal
