looking to sell the M600
    I am 100% but wouldnt the ambiant outside temps differ between Canberra and bumfuckidaho (wherever you are moving too)? May effect tune/ing???
      umm no,
      There are some situations where by you need to tune the charge air temperature correction factors (your actually mapping the volumetric efficiency of your engine) but they are rare.
      The air intake temp sensor will take care of the rest, along with the manifold pressure sensor.
        Wire what you have up properly, its an awsome computer which set up properly will serve you well or remove the motec, fix the std loom up and fit a powerfc.
        Originally posted by Einstein
          Sell the M600 to me Phee, I'll be your new best friend
          :huh:
          ― Jim C. Hines
          ― Daniel Patrick Moynihan
          ― Napoleon Bonaparte
