Hi All,
Bought a cheap ebay scan tool to plug into a mates AU falcon (classic 6, EEC-V ecu), and surprise surprise, no go. It doesnt even register that it's connected!
After much much digging on the net, I am led to believe that the AU uses an OBD-II compatible protocol called J1850-PWM, but a ford variation of that called SCP (Standard Corporate Protocol). Basically, it seems to be that the diagnostic port uses a different message format of the basic j1850 protocol that normal (cheap) scan tools cannot cope with. A different data frame structure.
Was hoping to extract DTCS, Live data etc from the car.
Has anyone had experience in using this protocol and if so, can provide any info, pdfs or paperwork like:
-SAE docs that used to be free on the net - j1850 standard, j2178 all parts, j1979, j2012, j2190, j1978, j2205
-Ford SCP Information (any and all)
-Ford Nodes/PIDS/IFR (In frame responses etc) etc
-AU Falcon DTC diagnostic trouble codes (are they listed in a service manual?) The standard obd ones and also the extended ones too.
It would be nice to get some data out of the ecu, but there is so little real information on the web to connect to any ecu that uses the SCP protocol. I think I have looked for days and days and downloaded so much that its not funny, but its mostly crap.
If I know the data structure I can most likely reflash a/the scan tool to cope with it and finally get somewhere. Obviously not wanting to go to the level of a ford WDS which is $$$$$.
Perhaps the developer of Niss/Sub/Mits data scan may be able to help, sorry dont know your name mate. :-)
Any help at all would be really good.
Cheers,
Beefy.
Cheers,
Beefy.
