vipec
    lol he is lucky that she may or may not be on leave so i cant tell her any latest purchases
    I think i might have to invest. Might see the differences between v88 and v66(as i would get plug in model)
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
      What sort of $$ are the vipec's?
        about $2600 inc GST for a V88 with flying lead loom, intake air temp and coolant temp sensors. There was a price rise at the start of may. The V44 is about $1800.
          How does this automatic tuning work with the Vipec?
          Originally posted by Marv
          She most likely doesn't bathe, thinks basket-weaving should be in the Olympics and has a vagina that looks like Dumbledore's beard.
            Same as it does for any ECU with an autotune facility. You input a lot of AFR targets into a table and drive around with the wideband plugged into to it, at various loads and speeds until the ECU has mapped itself to give the AFRs that you asked for.
            Doesn't do timing.
            Originally posted by bugle
            The non GTS's were gay
              in process of selling my power fc and nismo AFM's, buying a plug in vipec.
              3D scanning
              3D modelling
                MAP sensors and 6 Throttlebodys are Crap, Many ECUs stuff around with TPS v MAP etc but its still crap. Single Throttle conversion is the only way to solve the pulsing.
                GURU ENGINEERING PTY LTD
                  or just take off from the gtr balance tube
                  3D scanning
                  3D modelling
                    Still pulse, Datalog a power run and have a look at whats happening.
                      i will next week when i get it. If it was that much of an issue the fpr would pulse too.
                      Just thought about this before, i data logged every power run on the DD dyno and never see any fluctuations.
                      3D scanning
                      3D modelling
                        I spend much time on the Dyno finding fix's for this problem and get good gains from it.
                        I went back to AFMs on my GTR and found huge gains and much better mid throttle control at higher RPM.
                          yep AFM's on GTRs are unfortunatly the best way.. Power FC djectro's are fucking cunts on them as are all map sensored ecu's.
                          but fuck off the ITB's and all is good
                            might just keep the power fc then
                            fucking cunt of a thing cant find my usb to serial port adapter.
                            3D scanning
                            3D modelling
                              PFC or Nistune are great on GTR.
                                if you already have the PFC stick to it, if you dont then get nistune...
