connecting generic TPS
    I have to add in a TPS and the sensor came with no connector (wires only) what is the best way to connect into the existing harness? previously ive crimped the ends with bullet or spade type connectors is this a good way? i want to try and minimise any noise in the signal
    where would i get good connectors (other than those you get at jaycar or supercheap which are probably crappy)
    other recommendations or tips?
    E30 325is M20 3.1L
    solder + heatshrink. simples.
