Counter-clockwise TPS?
    I need a TPS, and although the 1FZ toyota one bolts up nicely to the aftermarket TB, it spins the wrong way.
    Any recommendations for a car from which I can get a simple lever type (ie not shaft driven) TPS with counter clockwise rotation?
    Pic below is a toyota one as an example of the style I need.
    Cheers!
    1JZ/2JZ TRAC Position sensors are basically the same as the normal JZ TPS but spin the other direction
      Killer.
      Thanks jase.
      Now to find one.
        will have a look in the shed, fairly sure I've got a pile somewhere from JZ throttles I've deleted the TRAC from
          Have some if Jason doesn't.
