Haltech elite..
    Haltech elite..
    11 days to go,
    Yes have been testing for a while now, done over 1000hp with ease, intergrated with smart wire etc
    16 injectors
    Gearbox bump
    Boost control
    Flex fuel
    4d fuel and ignition
    Timed blow off valve control
    Ask away,
    How does the trans bump work? Pwm out the trans brake solenoid?
      Yes but it is all controlled by the ecu now, you have a switch input to the ecu for trans brake, a bump button into the ecu, so pressing trans brake brings on your aux rev limits and launch control stuff and activates bump control, then pressing the bump button reduces duty to the soloniod via a solid state relay, you still switch the pos side of a 2 wire soloniod off the button but on a single wire you switch positive and reduce the pwm..
        Tidy up the wiring cunt
        Originally posted by cheapracer
        Sperm are clever little fuckers that got us where we are today. You've never heard of pre-cum by the way?
        Originally posted by Nugs
        That's why I punch myself in the nuts before sex, get them disorientated.
          What's the unlabelled black box?
          Originally posted by piss98
            Ok thanks for the explanation. I am going to need an i/o for sure.
              Internal wideband? or have to run that external box?
              Transmission control?
              Logging to usb?
              Knock sensor?
              software available for download?
              Originally posted by ALLMTR
                Will this run a LS in a 260Z?
                  Logging to usb?
                  Knock sensor?
                  External wideband
                  Transmission depending on what it is could be done,
                  logging to USB is coming
                  Dual knock with long and short term trims
                  Long and short term fuel on dual banks
                    Internal logging is 40 channels for 90 minutes too
                      It has a solid state for gearbox bump in it
                        External wideband
                        What is the thinking behind this vs internal wideband?
                          Cost mostly. The can widebands are cheap and if you have a V engine going to a dual channel gives you left and right bank fuel trims etc.
                          Most people already have a wideband as well.
                            Why is the can channel in the waterproof connector shield, so if you want to use it for anything remotely wet like a street car, while using can, you leave the USB/can/logging portion uncovered in the 'water resistant' ecu. Wish they'd spend a few dollars and change it to a waterproof connector on the side for can like an auto sport or DT and have an optional waterproofed cover plate with pigtails hanging out for the log/USB ports.
                              Also the digital wideband is fucking awesome. No pressure compensation like the AEM but shit works beautifully and gives no fuck for weird voltage issues etc changing outputs. Love mine.
