Haltech elite..
    You just wire your can into the main connector and problem solved.. There is 2 can channels you just choose in the software which can port you want to use..
      Dale can it do VE on a Rotary? What is the injector staging like?
        No rotary support at the moment if ever..
          I have one question what will I need to run a 5L holden V8 just the elite it's self? This is for my ute it may get a supercharger later down the track which I will be running two extra injectors. Is there a chance that I can get a rough price? I want to throw the wolf 3d in my ute at something fuck it is a piece of shit.
            Also how much is a electronic throttle pedal and throttle body that can be used on a VS commodore?
              What in the fucking fuck is so wrong with you that you would run "an extra injector or two?" You are potato of the highest fuckup. This is 2014, not 1994.
                The supercharger kit uses a Whipple and has two bungs that point at the rotors I would be using E85 so I would be chasing the cooling effect of the fuel FWIW.
                  to answer your (stupid) question, an Elite 2500 could run your V8 engine stand alone, and you could use built in outputs to drive your 'extra injectors'. But you never will as you are a 'gunna'
                    Thanks for the reply. But I sort of need a new ecu for my ute (I have no standard ecu and a half fucked wolf) I just wanted to clarify that I can just use the one box and have some one like dale to tune and be done with it.
                      Dale would love to tune your ute
                        Retracted. It will still never happen though.
                          As in no rotary VE and automatic staging or no rotary at all?
                            No rotary at all at the moment.
                              Well thats not very good? Wouldn't rotary's be a big market for them now?
                                No, not a big market at all. To be honest, more hassle than what they are worth IMHO
