ECU Tunes and Installs
    I'm back from my day job and have a bit of a backlog to work through for ECU installs and wiring. I thought I might post some pics and details of how I install and tune on different cars and ECUs.
    Starting off with this 1JZ Soarer, running some cams, a new turbo, 6 boost manifold and a 1280 ECU. It did come in with a dead PowerFC, and had it not broken they are really capable ECU's if you can work around their idiosyncrasies. This one was faulty (Failed chip when warm causing hesitations), so we decided with the Adaptronic due to many factors.
    The Adaptronic has 12 injector outputs, 8 ignitor outputs, 8 high current aux outputs, 8 digital inputs and 16 analogue inputs. The beaut thing about these ECU's is that the injector and ignition outputs can be re-purposed to high current aux outputs should you not have 12 cylinders. The wiring diagram does assign wires to specific roles like MAP and TPS to certain analogue inputs, but these too can be changed in software should you make a mistake wiring or want to do something different.
    I always start with a IO (Input/Output) count and either write it down, write it on the wiring diagram, or if the software allows, just enter it straight in to the ECU. After playing with the new Haltech range, they have this function now too. An IO count and diagram really helps you get your head around where to start and gives a good indication of progress.
    From there I start wiring, usually ECU power, relays and anything 12v. With most modern ECU's, you can retain the standard EFI relays, ECCS etc etc sort of stuff and have it triggered by the ECU as if it was the stock ECU. This is a very nice way to do things, as it retains fuse/relay functions and wiring diagrams. Often you have to drive ECCS relays high, which is something some ECU's are not capable of doing without an interposing relay. The adaptronic can do it with the tick of a box in the software. Aux out 7 is used to turn on main efi relay in this car.
    We are doing some cool things on this car. Turbo speed can be wired straight in to the ECU as a hall effect. Re-purposing VSS4(vehicle speed sensor) input, we are able to scan incredibly high frequencies and do simple calculations on them in the ECU to output turbo speed. This will later be used to dynamically check boost against turbo speed for compressor efficiency as a calculation within the ECU and for logging. Here you can see the logic change involved. This change had to be done in advanced view, as it is somewhat of a hack to the standard ecu firmware, simple never the less.
    Another cool thing is oil pressure and fuel pressure. Using sensors mounted in the rail and the filter housing, pressures will be monitored and checked against a expected value for any given RPM or MAP and flash CEL or initiate fuel cut if out of tolerance. Fuel will be done by using a measured base fuel pressure and subtracting MAP from it. so if we say there is 270kPa of fuel pressure and we are 30 kPa on the MAP (70 kPa vacuum) then the fuel pressure should be 200kPa. This assumes a 1:1 fuel pressure regulator. If this doesn't work we can always do a log of fuel pressure and just use a 2D table to compare with. Oil pressure will be a 2D table of RPM vs pressure, and compared to actual pressure. A banjo bold was skillfully machined to fit a 1/8th sensor.
    As always, triggering is very important and although this is a very well documented trigger system, I thought I would run through the motions of setting up triggering with an unknown CAS for demonstration. Using a scope, we can see the top wave as the crank wheel and the bottom wave as the cam reset wheel. The crank has many teeth and is used for high resolution fuel and timing triggering as the motor spins. The cam reset wheel is to tell the ECU that the engine is at TDC as a reset/refresh of the engine rotation counting. The bottom wheel alone, with no missing teeth, isn't helpful to the ECU without a reset pulse which the cam provides. Fun fact about the 1280 is that it has an internal scope on all calculations and IO. This is very handy as it lets you see engine angle count up while watching ignition, inject and CAS events. It's interesting to note the waveform rises first then sharply falls. If polarity was incorrect on the sensor, it would fall first then rise sharply. I wire in a rush and get this wrong seeming more than random chance would allow. My scope pic followed by the adaptronic internal scope and ignition/inj events.
    This car is now running and after tomorrows road tune we will head to the dyno for a power run.
    Jason Broadhurst
    Awesome. Very informative.
      So much nerd. well done.
        Cheers, mate, the way you sorted shit out on mine was awesome. Great to see in this level of detail.
          2 789's, bastard..... I want one of those, struggling to justify it though.
          Nice setup and rather informative.
            I popped in during this install. I can confirm dr who and Star Trek were playing on the tv whilst Jason watched the owner work
              Very cool, and relevant to my current interest!
                Start a blog. Nekminnet: #tunedbybuthurts
                  Should really get you to spend a few hours fine tuning ute on street with me for super economy. Love it
                    Great write up... Have been interested in the adaptronics for a while so keen to see more.
                      Appreciate the insight.
                      Love the turbo speed measurement!!
                        great write up!
                          No Haltech, no care.
                          So keen to actually do something with my project.
                            Needs more Ethrottle.
                              JZ are my bread and butter lately it seems :D How is yours going?
                              One for simulation and one for verification :D
                              It hasn't been the same without David Tennant
                              Shutup and update build thread :D
                              Nekbeardminnet. I could get some stickers made.
                              Bring it around already.
                              Monday coming is a haltech FJ20 DR30 FWIW :D
                              If it were up to me :D
                              Jason Broadhurst
