ECU Tunes and Installs
    Jason Broadhurst
      Absolutely beautiful work.
      Under steer is hitting the wall with your front end. Over steer is hitting the wall with your tail end. Horsepower if how fast you hit the wall. Torque is how much of the wall you take with you after you hit it.
        I wish my wiring was that nice haha. Halfway through putting an M2000 on a mates 2JZGTE aristo at the moment, just a splice job as he's keeping most of the factory stuff and can't be fucked doing a whole loom:
          anyone else had issues with dirt and grime getting into the loom with the braided sleeve?
          I tend to use it minimally now and stick with the OEM type PVC or whatever it is tubing.
          The braided stuff became a real pain on one car in particular that had a habit of overflowing it's catch can and overflow bottle
          I've got almost full rolls of the braided stuff in pretty much the full range of sizes so it's a bit of a shame
            No issues for me using the braided stuff. Occasionally gets caught on something when pulling the loom, but that is easily resolved with better Pclips.
              I would prefer PVC sleeve personally, but it's much of a muchness. I don't subscribe to heat shrink loom group, because it tends to make things far to rigid, almost composite(wire, glue and dual walled tube) hard.
              I actually use kapton tape under most of the big glued heat shrink sections to avoid glue ingress in to the trunk of wires.
              The heat shrink is all 120 degree rated.
              Jason Broadhurst
                I dont use braided sleeve because as soon as you decide you want to add another sensor or realise you hooked up the wrong wire somewhere you need to chop it up. Nitto tape and split tubing ftw
                In terms of heatshrink I use mastic-lined stuff to help keep joints sealed. Just jaycar stuff cos im lazy and dont do enough of this stuff to warrant anything more than that, I just help friends wire up shit from time to time
                  Some people want heatshrink, some want braid, some are happy with a wrapped split tube loom.
                  Provided any type is done well your laughing.
                    This is what i ended up with
                    All up its not as nice as some i have seen and worked with, and its certainly not motorsport/milspec quality. But its functional and will work well enough.
                      Who did you get the braid through?
                        Looks pretty damn good from here
                          Red and black i cant remember, was left over from the AE86. The straight black stuff is Jaycar.
                            This shit?
                              Nah. This stuff
                              https://www.jaycar.com.au/expandable...-x-2m/p/WH5585
                                Thanks Chris, harness looks good.
