Wrapping looms - what's the hotness?
    Wheres the best place to get the braided sleeve and glued heatshrink from . about to do a turbo aircraft loom and want to make it look nicer than the split tubing i normally use on cars.
      There was a mob on eBay based in Sydney selling just about every size/colour combo by the metre. Stuff seems a bit heavier/less flexible than the Jaycar/Electus black hobby stuff.
      They also did the heat shrink.
        www.techflex.com.au
        Thatís who Iíve been buying from (as above)
          Are you qualified to wire up an aircraft?
            It's for a homebuilt of some description.
            Some of the previous Suzuki motors he's put together are powering powered trike hanglider things.
              Originally posted by Aaron View Post
              www.techflex.com.au
              ok thanks, so ashdown ingrams is the distributor.
                Hence I'd never fly in a homebuilt.
                  Gamma knows.
                    CABEC have it in lots of sizes too
                    I'm not going to comment on if Dave should be wiring planes I've seen his cars.
                    Jason Broadhurst
                      DCI Performance Products, all either Aussie or USA made, supply to the aus military, Holden, Ford etc
                      Anything anyone needs let me know, if we dont have it on the shelf, its next day http://www.dciperformance.com.au/pro...ose+Protection
                        I would, but only if i'd built it!
                          I've flown on all of the aircraft I've fixed over the years, but only because I know how many redundant systems there are, lol.
                            [removed].
                              Any good sources for firewall grommets with boots? Want to reuse the AC holes for wiring.
                                http://www.harnessmaster.com.au/
