DIY Ardunio Project
    Hmm, I'll have a look at what's got pull-ups, that's something I've not clarified, ta
    Everything is 5v, no mixed voltages anywhere (though I'll go double check all the jumpers now)
    Clock speed I'll fiddle with once ive checked/confirmed hardware/wiring.
    Im also going to try changing the temp sensor address (even though it doesn't appear to conflict, changing it might do something?)
    Mit freundlichen Grüße
      Got a scope?
      Jason Broadhurst
        Nope. Prob would be helpful tho. Those el cheapo mini digital one on eBay fit for purpose?
          Not for comms really.
          Jason Broadhurst
            yeah, then no.
            wonder if i can find an ancient CRT scope for not much on gumtree
              Home from work in Aust and had my shapeways waiting for me proceeded to promptly cut up and install a myriad of super seal fittings (though my 5pims haven’t turned up - grumble).
              All kindve working out ok so far. Will make cable routing sensible/traceable.
                Very tidy man
                Jason Broadhurst
                  yo, i have a scope but u building this over there yeah?
                  www.holditflat.com
                    Yeah, muddling away with it over here.
                    Weird temp sensor/gps incompatibility persists
                    Originally posted by Jason Broadhurst View Post
                    Very tidy man
                    thanks broseph. i like neat... especially stuff like this, otherwise the spaghetti gets wayyy out of hand
                      Ed, where did you get to on this one? Did you just go with the RaceCapture Pro in the end?
                      Looks like you got far further along than my little effort: http://www.performanceforums.com/for...logger-Project
                        nope, the coder who was helping me ended up being a waste of time, and its not something i can really dedicate the time to at present to learn.
                        the race chrono otherwise does pretty much what i want, just the tyre temp sensor expansion part ends up being more expensive (albeit simpler, and known to work).
                        still have some ideas which could be interesting to implement (active aero) so have the gear still hanging around, but well and truly on the back burner.
                        that said, if anyone wants essentially new hardware, id sell it on
                          Fair enough. Are you settled on the RaceCapture Pro that is in the 110 then?
