Emtron KV ecus
    No reason, I'll end up using cal control for flex fuel most likely initially. Longer term, i'll use it for varying stages of torque management / traction control.
      What do you mean cal control for flex fuel?
        Fuel enrichment for %ethanol.
        Or, if you chose the option for "Custom - Table" under Stoichiometric Ratio Setup, and use "Stoichometric Custom Table(s)" mapped against %ethanol, it should automatically compensate Lambda Target Table 1 when it detects a given amount of %ethanol?
        Or am I completely wrong and that is one of the functions of the Lambda Target Offset Table?
          All good - when it's connected to an Ethanol sensor, it automatically compensates based on the Stoich Custom Table.
          It also automatically pulls fuel temp from the Ethanol sensor for use in the Fuel Density table.
            you got an email address? I'll send you a file with flex already done on it. so you can have a look around.
            PM me.
            Oo___oO
              Yeah nah, its all done by fuel density and automatic.
              y
                Finally got a quote out of Chequered.
                Seems that there is nothing in these money wise? Happy to pay it, but would rather put a bit extra toward dyno time.
                  i can quote you if you want...
                    Please do Dale. After KV8, tuning cable and the ECU mount. Will need freight to Melbourne, shoot me a PM when you get a chance.
                      i'm in Melbourne. I might sell my Emtron KV8 if you are after one urgently? unused in box. only reason being is i dont need mine yet and will just buy another one.
                      i also got mine in melb via quickbitz in dandenong,
                      CISCOKIDS
                      The Gentlemen's Club
                      Midnight Rocker
                        Not urgent mate, but thanks anyway for the offer.
                          Edited.
                          CISCOKIDS
                          Midnight Rocker
                            KV8's don't come with the tuning cable do they?
                              Nope.
                              CISCOKIDS
                              Midnight Rocker
                                Thanks mate, just wanted to confirm.
