Emtron KV ecus
    you can just terminate a cat6 cable into the ECU plug though. its nothing proprietary.
    then use a female cat6 wall socket mounted to a kick panel or something
    Oo___oO
      Thanks for the reminder, I do remember that now. It's what I had planned to do in the first place when I was planning what i/o I need.
        So Emtron pretty much wiped the table at WTAC... Thats all...
          Any/stat details on that claim?
          Jason Broadhurst
            Originally posted by sssgtr
            Were any WTAC entries running Motec ecus?
            emtron had given all the motec runners free ecu's
              I deleted my post because it was kind of retarded.
              How much truth is there to that dale?
                about as much as the ecu making a car fast around a track when its all aero that makes or breaks it.
                    I would also like free emtron
                    Lol
                      I think If i was at the pointy end of that field i'd rather be using i2/gems/racestudio 3 for comparative log analysis, I'm currently working on getting a 50hz GPS module working with mine over canbus to the KV8.
                      But I guess they're all still running Motec dash loggers (RP968 is an emtron ecu with a motec dash) so i2 is still available to them.
                      the sequential gearbox control (closed loop paddle shift control/shift stacking etc) and the driver torque request throttle mapping in the Emtron is very trick though. (motecs GPRP can do this stuff, but Motec and Emtron are the only options around this price point).
                      The DBW BOV the time attack cars are doing with the Emtron is also a neat trick to maintain compressor speed.
                      not a bad deal getting a ecu for free instead of the $5100+ a M150 GPRP would set you back
                      Oo___oO
                        I disagree. with DBW turbo cars with integrated paddle shifted gearbox control, the pedal demand/torque request mapping can make a massive difference to the drivability of a peaky 1000+hp car. you can ask for 760nm with your foot and the ecu does the rest, and blend car speed/lateral G force into that demand table to account for grip due to aero load/traction circle differences.
                        Oo___oO
                          I know how it all works, its nothing new, these cars have so much aero that they are under powered,
                          people don't take off M150s because they are paying for another ecu..
                            I'd like to know why they're taking off M150s at all
                            Oo___oO
                              Sponsorship and free engineering would be pretty enticing.
                              I should have entered my barina with the old M4 in my drawer.
                              Jason Broadhurst
                                RCP v2 or v3? Or other GPS unit?
