Black Box PDM's
    Black Box PDM's
    GR Motorsport Electrics is a dealer for these, pricing is around the $2200 mark for the 30ch. Not a great deal of info though.
    Stay away and save up for a HP Electronik 8441 / Motec PDM30?
    You’re not serious are you?
    Checked date and its not april, so you’re serious.
    Fuck. Get help.
      man the Motec M30 is only another 700 bucks. you'd be nuts.
      Oo___oO
        Point taken.
        Apparently the HP Electronik 8441 is pretty good. But again, for the extra $400 gets me the motec.
          the electronik is suppose to be good, haven't seen one tho.
          I still like the racepak one if your using a supported ecu, they are simple to program and work,
          I would probably give anything black box a miss.. if you have more money to spend buy a motec one.
            Fucking motec....$300 for the UTC adapter just to program it????
              lol yeh… they are not cheap...
                That turns the pdm30 into a $3200 affair.
                Bit shit when the HP 8441 is $2400, you're not the only one Dale who has mentioned that they are supposed to be a good thing.
                  You can borrow a utc from anyone, you’re not programming a PDM often. Plan, do once. I’ll lend you mine if you’re in bris.
                    ive never programmed one, I have tuned a car that had one installed in it, there was no electrical issues with that car and it appeared to work perfectly..
                      It seems you're approaching this as an item by item approach SSS. You want an entire system. Everything will more or less do the job more or less as capably as it comes to running an engine, and turning shit on and off.
                      You're using an emtron ecu? Excellent, motec pdm, dash. Job done.
                      Using a haltech? throw a racepak normalintelligence-wire at it.
                      Syvecs? then life racing pdu, and plex dash.
                      Motec? well thats obvious.
                      Some shit just works easier, more streamlined and has been done a thousand times. Trying to save $500 will lead to $500 in troubleshooting and thrown tools and frustration later. That adds up obviously. Yes the PDM will cost more. And you probably want to spend more than that and have two PDM's anyway depending on chassis setup.
                      Skimping on the dash to use an aim or a racepak over a motec? Well have fun using a keypad to cancel warnings, adjust settings/brightness/screen flip/see adjustments and map switching/trims etc.
                      Good thing with emtron logging is it'll log all the pdm channels and sundry data.
                      It sucks but the industry does not mix and match too well, despite being a huge jump ahead of even just a few years ago.
                      Examine the reasons you're using an Emtron in the first place and you'll find its because it's a 3k saving on an M150 being built to identical capability in firmware and an LTCD. Hell an M150 and M1.4Dev license is $6k before you've paid a single person to type a line of code to get something you want working.
                      Also remember the interface is what matters most once the capability is there. The prettyness of the anodizing and the flash website means fuck all, if once you're in the car the user interface is cumbersome and unintuitive and you have a dozen analogue switches and dials and crap that could otherwise be on a single keypad or rotary switch etc. If the dash doesnt tell you the information being gathered by the bus and available your troubleshooting is suddenly multiple open programs etc and comms conflicts with laptop and...fuck that noise.
                      Speak to your dealer. Write all your inputs and outputs down in excel for all hardware. Assign every channel and wire and input. Repeat and compare between brands.
                        https://www.liferacing.com/products/pdus/pdu34a/ no UTC needed, saved you $270.
                        Waiting for new motec PDM's that can do comparable shit like the 10k hz low side switching for pwm high current control. I'm sure they're in the working on it as PDM15/30/16/32 are getting on in age.
                          I wish more people had your thought process haha. Well written
                            if you have any outputs that need that kind of hi frequency hi power and you still have the emtron KV8, the DO 13-16 will do 15/40a at 15khz. I'd high side drive it so you can use the separate power supply input and not saturate the ECU grounds. what needs the 10khz?
                            Oo___oO
                              Exceeding audible levels when switching bigger pumps. PS pumps whine like cunts at 100hz. Also wreaks havoc with hall current sensors switching at low frequency. Maybe pdm’s handle this with averaging, but inputting 0-5v off little allegro sensors would be all over the shop (or it’s a function of cheap sensor? Fucks me). Assume same applies to fuel pumps etc.
