Black Box PDM's
    So much for a productive thread about PDM's.
      you shouldn't be using the e888 Comms modes to talk to the emtron. I'm betting racegrade have fucked up the e888 message framing in the firmware If dale sees the issue in haltechs too. if you read the manual for the tc8 the first 4 modes 0,1,2,3 all use the e888 messaging format that sends lots of useless information like cold junction etc. Use can mode 4 of the tc8, create a custom RX frame in the emtron with 8 words starting at your tc8 device address and read egt1 to 8 in big endian. The value coming in is in 0.1 degrees. They can't fuck that up that framing code.
      Otherwise use a canbus USB adapter and use their config software that also displays the temps from the unit
      Oo___oO
        Thanks mate.
          Yeah so putting the PDM on hold for the moment, unless something better comes out, picking up a HP8441 over in Austria next year.
            I used mode 4 not 0-3... the haltech does not accept a e888 can config
              Well I guess they're fucked! I'm out of ideas
              Sent from my S61 using Tapatalk
              Oo___oO
                I use a ecu master egt box. It was $150aud. It only runs at about 4hz update due to probably only having a single ADC that must be multiplexed to sample the 8 channels but that's fast enough for my needs. Works perfect and is cheap as fuck. you can disassemble easily to solder a termination resistor over the can hi/lo pins inside to make the wiring neater.
                https://rrrshop.co.uk/8egt2can---8-t...dule-403-p.asp
                this was a stop/start log hence the jumps between pulls. also cyl 6 is a bit cold but as it is an RB26 with standard intake manifold I wasn't game to lean it out until we looked at the plugs!
                Oo___oO
                  I can say that I've seen similar issues in EGT data coming from an AIM EVO4S to a Link G4+ over CAN, when I screwed up the CAN receive frames on the Link :p After I sorted out the configuration is was nice and smooth without the random spikes/drops
                    What was the issue with the CAN framing you had?
                      I'd screwed up the framing to be most significant first instead of least significant, was shocked it was actually transmitting semi-sensible figures at all. Was flying blind though as AIM weren't that forthcoming with their smartycam frame format
                        with the ecu master egt box can you configure the CAN data to replicate a Haltech EGT box. or does anyone have the Haltech EGT CAN Protocol info?
                          nah it just spits out 8 channels of temperature data over 16 bytes, two bytes per channel. scaling is 1=0.1degC. you can select little or big endian and chose a CAN address but thats it.
                          Oo___oO
                            Haltech can stuff you can pull from plex software.
                              I've managed to talk myself out of the HP Electronik unit.
                              - cost of it and the keypad comes out to only $170 cheaper than the Motec PDM30, UTC adaptor and 15 button keypad
                              - HP PDM has to go back to Denmark if it fucks up, Motec unit goes 15mins down the road for repair *if* it actually ever broke
                              So with the PDM30 - is there anything coming down the pipeline from Motec in regard to a newer model that I should hold out for?
                              Is there any bad points about going with the PDM30, aside from the 100amp max current limit?
                                Also interested, when I rang motec they did say some people but two 15s one in the front one in the back.
                                3D scanning
                                3D modelling
                                Structural certification
                                3 and 5 axis milling
