Ls ecu with a dry shot
    Can a factory LS1 ecu be tuned to compensate for a dry shot of nitrous?
    Yes. A mates lsa is tuned like that and that's on earlier ecu as they swapped reluctor wheel and back to cable tb
    Originally posted by 50RTD
      I think they used open/closed loop tables with an arming switch to change
        I havenít bothered with a dry one. Years ago there were guys using air temp to enrichen and retard and using the factory shift light output to turn on the gas. I donít get it when you can run a plate behind the throttle and a short bit of hose from the port on the rail
          I think EFI Live COS5 had some nitrous shit in it. Will look in the morning.
            Hoonboy has a dry setup in his Commodore - C&V tuned it.
            www.vsport.com.au
              yes its easy
                Can be done, but as BPM mentioned, the port on the rail is right there to supply fuel. Any reason you want to run a dry shot in particular?
                  i thought the main reason for a dry shot was significantly improved fuel distribution?
                  Originally posted by Skompa
                    A mate wants to do a hidden kit, itís easier to hide a dry kit
