Holley terminator x (LS swap market only atm)
    What are everyone's thoughts?
    https://www.holley.com/products/fuel.../terminator_x/
    Ls swap market obviously where its aimed $999usd gets you ecu touch screen, wideband and loom to plug in. For $1299usd capable of drive by wire or trans control like 4l80 and 6l80. 1499usd gets you one that can handle both dbw and trans control. The sloppy mech video suggests the 4 user config outputs means its Capable of nitrous control, flex fuel, and boost control. Also self learn fuel trim is a big one for me. But looks like it can do whatever Depending on what you need/want for your average street car.
    If it existed when I built my car I would have bought one and I think I'd like to use one when I swap to a 58x engine but still early days and not sure what the feedback will be.
    I follow most of the holley efi stuff and this seems pretty good.
    Originally posted by 50RTD
      I was pretty close to buying a Holley dominator for my TT LS project but couldn't justify the $s over a Haltech elite given i had a usable loom and easy local support.
      I think if i had my time again id probably go terminator X. With the loom it seems like crazy value and will be well supported. On board 4L80 support is awesome as well.
        Is it programmed to starve fuel when doing donuts?
        Originally posted by E-Z
          I wonder what Terminator X has to say about this. Donít believe the hype maybe?
            Looks good.
            If I hadn't recently bought HPT I'd prob be on it.
              ain't nothin' butta ecu
              Originally posted by Skompa
                I've tuned two now. Fucking great easy gear.
                Not scalable, but they are not designed to be.
                Jason Broadhurst
                  It's only been out a few days? Or are you referring to the dominator? From what I understand very similar programming.
                    Oh right, yeah the one which has been around a couple of years now.
                    Jason Broadhurst
                      they work ok, they are 100% not repairable, so if you burn out the wideband or melt a wire and cook it then its in the bin...
                        Does it matter? It's $1k us with harnesses, ecu, and sensor and screen. Imagine what a replacement ecu only is on the unlikely event it dies. It's pretty much a throw away ecu.
                          throw it away or send one back and get it repaired? i know what i would rather do and thats support australian made
                            What's that repair cost if its deemed user error caused the problem?
                              If you blow up your Ecu? Holley is full replacement cost, most Australian ecus would be under a couple of hundred
