ECU wires - where to buy?
    https://www.efihardware.com/products...-diameter-hole
      Yeah, saw those. Still stings when you need only 1.
      Gah, was out there yesterday and they said they had nothing like that. :S
        I was pretty sure EFI Hardware had just started advertising those boots.
          Yeah, probably didnt know they were in. But still annoying.
          This one looks like a good option for me:
          https://www.efihardware.com/products...-for-65mm-hole
            I like the strain relief on both sides.
              Yeah, so do i. That is what is selling me on that grommet.
              Now to just drive out to Croydon again...
                May as well post here since it's relevant.
                I've got the 2 wire Bosch knock sensors on the 2J now which needs wiring. While I'm at it, I would like to replace/upgrade the crank trigger and cam home cables too.
                What's the current hotness (and where to buy) for some screened twisted pair cables locally?
                A bit of googling found this from UK which looks the part;
                https://shopbhp.com/collections/cabl...screened-cable
                From RS-Online;
                https://au.rs-online.com/web/p/twist...cable/1223058/
                or
                https://au.rs-online.com/web/p/twist...cable/7491627/
                Not sure on the sizes though, and would prefer to buy per metre if possible?
                Appreciate the help guys.
                  for crank/cam and knock sensors I use this stuff: https://www.motorsportelectrics.com....-screened-wire
                  You can use the twin core mic cable you've linked if you want though, will work fine. That's similar to what Link and others use in their long flying looms
                    That's what I'm after! Thanks
                    What size do you normally use?
                      I've got a roll of #20 and #22, I use #20 the most as that's the size which fits best for the Sumitomo TS / SL crimp terminals I have for the toyota crank/cam and knock sensor plugs
                        How much do you need?
                        I have a roll of the stuff somewhere.
                          At a guess probably around 5m? Crank/cam/2xknock with ecu in same place as stock Aristo... I was just going to buy 10m of the stuff. But I can help you clean your shed
                            I'll try and find it and see what it is exactly.
                            edit, this is what I have,
                            https://au.mouser.com/ProductDetail/...0IkHl6QQ%3D%3D
                            Pretty cheap compared to that other site, can spare you 10 metres if you think it's suitable and you can be bothered driving down.
                              That looks perfect, thanks man. I'll text you.
                                That looks to be abut the same price, GR motorsports electrics price by the meter and mouser price by the foot
