Current hotness for ECU input sensors (air/coolant temp, fuel/oil pressure)
    Oh nice, that would have been good to know last year!
    Norbie!
      Yeah, telling me too. I only found out about it just then.
        Just FWIW Mazda use the Bosch pressure/temp sensor and so it is available through them cheaper than direct from Bosch https://www.amayama.com/en/part/mazda/py8v18541b
        Any idea what model it is used on? Wreckers run maybe
          3, 6, CX3,5,9 apparently.
          https://www.onlinemazdaparts.com/p/M...Y8V18541B.html
            I’m pretty sure the fancy combined Temp/Pressure one is a fairly recent arrival so don’t ask a wrecker for one unless you have the exact year pegged down. All the early engines in the 3 and 6 were simple idiot light switches
              2016-2020 apparently.
                the connector they use is the worlds biggest cunt
                  I haven't got around to wiring mine up yet, sounds like I'm in for some fun!
                  Norbie!
                    I didnt find them too bad, crimped easily with the Engineer crimpers.
                      What is the go with bosch knock sensors? I have read there is both narrowband pre-filtered and wideband what has confused me is the part numbers/pricing i have found range from $60 each to $120 each and I have no clue the difference or what is required for my JZ engine.
                      Bosch part number 0261231188 - $37 from Taarks
                      Bosch KS4P "wideband" - $76 - Platniuim racing products
                      Bosch part number 0261231006 - $60 from Supercheap
                      CISCOKIDS
                      The Gentlemen's Club
                      Midnight Rocker
                        try depinning.
                          https://www.efisolutions.com.au/bosc...-sensor-10-bar then they come in stock, they were available a few days ago. Not sure how good it is to mount it on the engine for oil pressre/oil temp but fuel they would be awesome, some much less wiring and space
                            I'm not so fond of the combined pressure and temp sensors, but for pressure only you can get these speedflow hose ends (240-03) which the sensor can screw in directly and has a C-clip for semi-budget remote mounts.
                            https://www.efihardware.com/products...e-sensor-mount
ID:	7154429Click image for larger version
                              Can get expensive if you need multiple sensors for say Oil, Fuel and Water pressure though.
                              Anyone try out the cheap $25 sensors and have any issues with them?
                              https://www.ebay.com.au/itm/150PSI-P...frcectupt=true
                                Yeah. I used those back when they were $100 and the Honeywells were $300, shook themselves to bits in the race car even when remote soft mounted.
