Aftermarket ECU and A/C Pressure Transducer - Anyone Had Success?
    Got an aftermarket ecu to put on my turbo Getz. Keen to keep the a/c running.
    There is not a 'triple switch' that I'm used to but rather a 0-5V pressure transducer.
    I have the factory workshop manual but it doesn't mention the pressure/voltage characteristic of the transducer or 'switching' voltages (WTF you Korean cunts?!)
    Assuming the transducer needs to read up to 32 Bar, is there a cheap/easy way to measure the characteristic of a spare transducer?
    Would rather not swap the pressure transducer for a triple switch if possible.
    Cheers cunts
