Camshaft Vernier Pulleys
    Motor is an inline 4 cylinder DOHC. The camshaft sproket/pulleys has slots/raised items that go past a sensor to tell ECU where the camshaft is in relation to crankshaft.
    If I replace this sproket/pulley with a vernier adjustable sproket/pulley that has no raised item on it, and I run a Haltech Elite ECU, how do I tell ECU what the position the camshaft is at, or do I just run wasted spark?
    if you're lucky, you use a raised bolt head for one of the adjustment bolts and hope it swings past the sensor. and that becomes the cam home signal
    Oo___oO
      Jason Broadhurst
        Oo___oO
