HP Tuners - learning how to use it
    What’s the best way to learn tuning with HP Tuners? Is there a online course, PDF download or work shop you can attend to learn?
    thanks
    h
    There's a few online courses like HP Academy, some free ones on YouTube and some paid ones on Vimeo from Matt Happel and the like.
    The HP Tuners forum is supposed to be decent too.
    Check out Goat Rope Garage on YouTube.
      Thank you for the info
        Buy a car and tune it for 6months. Then modify it and tune it again for 6 months etc etc
        GM and ford stuff it fairly straight forward. Euro stuff is weird
          good luck ive had it since 2004 and still learn shit every day...
            dale, can you do HPT remote tuning? ie lotus on autobahn in germany?
              remote tuning on an autobahn??? Is that the tuning equivalent of a crank bearing inside another crank bearing?
                eh, wouldve thought thats the ideal tuning environment? endless road, low, mid, full throttle, lots of time, endless runs, great cooling, realistic conditions etc
                  I was thinking you meant full throttle live on-the-fly tuning with all the dodginess of internet connections, lost packets, phone data, bricked ecus from failed data flashes, etc. I see you mean the environment, which as you say very different to a dyno room.
                    if it was a commodore i would say yes... being i have never touched a new lotus i would pass on that one
                      Also have to flash it in makes it a bit of a pain
                      3D scanning
                      3D modelling
                      Structural certification
                      3 and 5 axis milling
                        its a 2010 GM motor
                          I'm not even going to pretend to understand HP tuners! It does things so differently when compared to a typical aftermarket ECU, that none of my knowledge crosses over yet.
                          It's tuning an OEM firmware, which wasn't programmed to be continually tuned so it seems a little convoluted to do some simple tasks. They also tend to contain a lot of redundant maps for manual/auto/sports/towing modes which adds a layer of complexity.
                          Jason Broadhurst
