The exhaust housing for my turbo sits a little too close to the thermocouple ports on the exhaust manifold causing them to foul on the first 3 exhaust runners.
Are there any low profile / different styles available that can be used in place or the standard 90 degree K type?
I've had a good look through Mouser ect but wasn't able to find anything too specific.
I am not too sure how fragile these are to be carefully bent where they need to be so not overly keen on doing that just yet.
Even worse with the turbo beanie on, but I can see how a slight bend could fix the issue.
