I've got a 2006 Territory that had the section of exhaust with the cat in replaced. It's an aftermarket item that after a few hundred km triggers the "catalyst below efficiency" CEL.
I'd prefer to not spend money on a new cat, or of course a tune.
So do those oxygen sensor extenders/cheater things make any difference here to avoid the code returning?
Does the ECU actually use the post cat sensors for trims or anything other than determining if the cat is working?
