6l80e control options
    What is bad about the 6L80E? And what is a better trans with engine braking that will go on the back of a LS?
    For the OP, Powertrain Control Solutions (PCS) make great controllers that can be tweaked on a laptop.
    Gimme mah $50 ya cunts.
      They just can't be made to be strong where some of the other 6 and 8 speeds can do 1500 ho with a few shaft changes.
      3D scanning
      3D modelling
      Structural certification
      3 and 5 axis milling
        i will elaborate on the nexus inputs a little more, it has the ability to use un used outputs as switched and low importance inputs, IE you can put the stick position sensor to IGN 9-10-11 etc, this way you actually do not use any of the 33 inputs to do trans control, you use 4 DPO outputs to do the 2 shift solenoids, Converter lock and line pressure control, even after doing that still leaves 3DPO, 4HBO as well as the 12 high current and 4 X high current, plus the extra ign output and injector outputs which for most setups will have 10 spare.
        by the time you buy a 2500, IO box, NTK dual wideband your not far off the cost of the nexus with all the fruit etc..
        Thanks for the detail
