wheel speed sensors
    Originally posted by burn is weird View Post
    Even a cursory glance at the tooth target spec of that sensor will tell you there will be problems with your toothed wheel.
    That tooth profile on your axle is meant for a VR sensor. A hall target wheel is square edged teeth. A VR target is points/waves
    Both the tooth hight and the gear tooth modulus are very fine. Maybe a spectec sensor will do the job. They have some small
    ‚Äčtarget options if you must go hall and use that ring. But a spec sheet saying a 2mm sensing gap is fine when the tooth amplitude isn't much more than that you'll have issues.
    100% correct,
    use the stock VR sensor and live happily ever after... your elite can take VR inputs on the SPI's
