    For one of my projects, in partnership with a couple of mates, we decided that the best way to make the prototypes we needed was to get an affordable 3D printer. So I did a bit of searching and found that the machine from here - www.pp3dp.com would be good enough to do the job. So I sold a couple of things to pay for it and got it shortly before the recent round-Aus trip.
    So far I've mainly just been printing various things for fun and to learn how it works and its limitations.
    The attached pics show mine, the ones below are from http://www.thingiverse.comreally slow; the big Enterprise saucer section for me took over five hours to print. Smaller stuff can take less than twenty minutes though.
    So just linking to the Thingiverse site to show some of the stuff I've made ....
    That's a three-piece rocket I made. With a little fiddling you could make it to take a model rocket engine. But there's other models on Thingiverse that already can take engines so no real need.
    That's a screw-on adaptor for a water rocket. You attach an air hose to pump pressure in and away you go.
    Rotary key rings. I've only got a roll of white plastic so that's the only colour I can print in for now. But there's a reasonable range of other colours now.
    A model rotary, to show how they work.
    A funny cube with geared corners.
    Oval gears that mesh together surprisingly well. The whole thing is pretty floppy though.
    To print stuff, it takes the plastic from the roll into the print head, melts it, then squirts it out a hole that's about 0.2mm diameter and lays down about that thickness of plastic, layer by layer to make up the object. So because there's only a very small amount being added each time, it takes a while for it all to happen.
    Here's a video of it printing the calibration piece.
    Sweet, I will give you your first job, If I send you a DXF or DWG can you convert it?
    I need my oil pump, alternator and power steering brackets printed so that I can check it for fitment before laser cutting it from Unobtainium.
      Yep can do.
        That's pretty cool, i can think of a lot of things where it would come in handy before you start machining metal.
          My drawings are only in 2D so is the thickness something you specify?
            I can give them thickness with Autocad. Something like 6mm or 8mm enough?
            Do you reckon they'll fit in the 130mm x 130mm table though? I can cut them in half if need be though.
              Bill this is so much awesome. Good on you mate!
                The important one which is the oil pump is 109 x 120 x 3mm, so maybe we just go with that one first up, I will send you an electronic mail.
                  Hmmmm .... see how it goes, it's large so the edges might try to lift but I'll give it a go - I want to try some clamps to hold the outer edges down, I think it'll help.
                  FWIW I just had a look at Rhino 3D and it can work with STL files ..... Uncle Torrence is getting a chrissy present for me right now in fact.
                    Cool Bill.
                    The rocket looks a bit too much like a penis though. Better stick to non phallic objects.
                      *winks*
                      Secret code noted, Muz.
                        Not wanting to take any work away from Bill!, but surely you would be better off having all your 2d brackets blazed out of mild steel by a laser cutter, or even paper print outs stuck on cardboard, rather than have them RP'ed. ?
                          Can you actually print anything useful with these yet?
                          As in, could you print say a car dash or something as an example?
                            Yes I generally had access to two seperate WJC, one is my previous company whom I'm now in oppostion with, and the second is my brother inlaw who is currently churning out 90 glass splashbacks a week, so it's kind of a difficult situation, I contacted two laser cutter companies this week and they haven't replied, I'm assuming that it's because it's a little pissy job? I was going to just use MDF or mild steel but I don't reckon I would get out from under $100 for a service charge from these companies.
                              You can do, but it'd probably still be more expensive than what I can do it for, and you can see if it's right & make changes if need be.
                              They'll only print little objects for now, it's still far cheaper to make big things the usual way. But it's still early days for them, I'm sure give it another decade or so and they'll be doing amazing things.
