Wanted to make some basic bins for some toolboxes and sent it to a place to print. Wanted 180 dollars so I said fuck that and have a lulzbot Taz 6 on the way.
Was it purely the bed size that made you pick the Taz 6 over the Prusa Mk3S or the Up Box+?Originally posted by PLAYA View PostWanted to make some basic bins for some toolboxes and sent it to a place to print. Wanted 180 dollars so I said fuck that and have a lulzbot Taz 6 on the way.
I'm looking at my options now. Prusa is nice any cheap but support seems to be an issue, UpBox+ is enclosed so likely to limit the smell of burnt plastic but the Taz 6 has a bigger bed.'93 6SPD T04Z 1UZ JZA80 Supra
'93 Auto T04Z JZA80 Supra
Venom Automotive - Billet Components to suit a variety of Automotive Applications including JZ, UZ & RB Engines.
I did some googling and I watch a dude on insta 3d magic mike uses a taz6. It has been not bad. I just bought an enclosure for it so I'll see how abs goes. It was average with no enclosure. I was going to buy an ultimaker. But that is 5k. Taz was 3500 but then factor in an enclosure 500 and say dual head for say 800 it's the same price. I'm not sure what I would do again. If time is worth anything to you I would spend up on purchase for less fuck around. Mind you I have never printer before and I was going pretty quick.3D scanning
3D modelling
Structural certification
3 and 5 axis milling
Still the best bang for buck IMO.. The MK3 is pretty well established now and the iterative upgrade MK3S is out as well as huge updates in the slicer software and firmware.Originally posted by sssgtr View PostHow are you finding the MK3?
I haven't spent a cent, or upgraded any part of it. It just works.
I think im going to upgrade my Voron soon, build a new Voron 2.1 http://vorondesign.com
The Voron 1 still works relatively well, but a few things are getting dicky with it, like the depth sensor sometimes just glitches out, and the E3D chimera hotend really cant dissipate enough heat when using both hot ends regularly.
The linear rails on the 2.1 look like they will add a lot of stability, and having it enclosed by default makes for a nicer environment.Chris
If you dig into the site then the manual has most of the info, and is really quite in depth. https://www.dropbox.com/s/rhljf791hx...anual.pdf?dl=0Originally posted by GSRman View PostThat voron website is sparse - im assuming the community links are where the detail is at?
But yeah, it is community driven since the main designer couldnt keep it up as a full time commercial thing.
I was the first to build a Voron 1 after the designer. its quite a good design.Chris
cheers for the feedback.Originally posted by PLAYA View PostI did some googling and I watch a dude on insta 3d magic mike uses a taz6. It has been not bad. I just bought an enclosure for it so I'll see how abs goes. It was average with no enclosure. I was going to buy an ultimaker. But that is 5k. Taz was 3500 but then factor in an enclosure 500 and say dual head for say 800 it's the same price. I'm not sure what I would do again. If time is worth anything to you I would spend up on purchase for less fuck around. Mind you I have never printer before and I was going pretty quick.'93 6SPD T04Z 1UZ JZA80 Supra
I have an upbox but its not exactly cheap. All my prints are in abs, PLA doesn't last from what I heard? Also I smell nothing when I print. ABS print quality is much higher than the examples in this thread usually.Originally posted by Brad88 View PostWas it purely the bed size that made you pick the Taz 6 over the Prusa Mk3S or the Up Box+?
