    Originally posted by fondles View Post
    Ive been using glass for a while, I purchased some sort of hardened glass already sized for my bed.
    I clean the glass every before every print with iso alcohol.... never had an adhesion issue, the freezer is a great trick for getting parts off the bed.
    Same
    But I got the matching Creality glass bed when I orderd my printer and have never used adhesives.
    I only clean mine once every 3 prints, followed by bed leveling.
    A few things I have printed lately.
    Dremal holder
Name:	217535739_10158985721147928_6881924011453398680_n.jpg?_nc_cat=101&ccb=1-3&_nc_sid=8bfeb9&_nc_ohc=yOzAOdJCB1wAX8wMoPT&_nc_ht=scontent-syd2-1.xx&oh=2173c320a9e2940d0d85d2e9b35f2ee9&oe=61261878.jpg
    Done upside down, messed up the top of his helmet a bit though.
Name:	214457542_10158972726977928_3822423345980948049_n.jpg?_nc_cat=108&ccb=1-3&_nc_sid=8bfeb9&_nc_ohc=eAqrsC_dNbEAX9_ksoy&_nc_ht=scontent-syd2-1.xx&oh=9bd870dfec2bc694bcc80397433964c5&oe=6123EFB7.jpg
    Loving this blue filament, but can be tricky to print without lifting off the best for some reason.
Name:	219325669_10158987920922928_86974668862818124_n.jpg?_nc_cat=105&ccb=1-3&_nc_sid=8bfeb9&_nc_ohc=QDljUtMX3OQAX88LL9Z&_nc_ht=scontent-syd2-1.xx&oh=d5d5a311d27d1097b1c2a0bc6b847cee&oe=612376AD.jpg
    _/ /___________\ \_
    /_________|_________\
    |OOO ___________ OOO|
    \______|====|______/
    [_]-------------------[_]
      Originally posted by ChrisS View Post
      Same
      Are you still running bed springs or swapped to silicon ?
      I use silicon and only bed level when I swap from glass to SSS build plate (sometimes I don't want the smooth surface on the part).
        The springs it came with, have ordered the yellow harder springs but that was before I discovered the in silicon strings.
        _/ /___________\ \_
          Finally got mine running from Pronterface now, over using the fecking SD card.
            Gents,
            Is there a way to slice a project but do multiples on the bed, but, have 1 at 20% infill, the next at 30, 40 and working up to 50%, or will i have to do them a batch at a time?
            Just doing it as a trial at the moment but just wanted to test out strength of the finished product.
            Cheers.
            I wouldn't recommend sex, drugs or insanity for everyone, but they've always worked for me...
              Originally posted by _Marc_ View Post
              Gents,
              Cheers.
              I just tried with prusaslicer and it not letting me.
              Does not want to import gcode.
                Yeah bugger, for some reason I thought it might have been attainable, ahh well batch at a time it is.
                Thanks for trying it out fondles.
                  Gents,
                  Cheers.
                  Looks like you can in Cura. Its called 'per model settings' on the left.
                    Fuckin Jimbo, Good man!!
