    Cheers, will give it a shot... was also thinkin of trying rudders at the end of the exhausts. I will be making a few test mules/prototypes to play around with this sort of thing on before I go the whole hog on a 1:12 scale version
    Originally posted by MIZ RX3
    IDB FTMFW
      Bill, are you aware of MakeXYZ?
      James
        I wasn't but am now, thanks!
        Just got an order to make five sets of headset thingies, but that was from another source.
          I found out about it about an hour ago, and figured it couldn't hurt to create an account even though my printer is still at least a month away. I see you've already got your account up and running.
          James
            Bill - how hard would it be to make motorbike parts (eg sprockets etc) from metal with one of these? My Dad restores old bikes and parts are impossible to find.
            (TM - AVENGE)
              You probably want something like this for sprockets ...
              James
                Not possible on mine as it only prints ABS plastic (lego plastic) but there are machines that can do metal that ends up a bit like sintered metal. But not all that strong because of it.
                What I'd be more tempted to do, depending upon the shape of the sprocket, is to either water-cut out sheet steel and/or layer it up with other water-cut sheets to make the desired shape.
                  Sprockets are definitely a water-jet cutters job. You can achieve very smooth edge finish on steel (if the operator isn't a muppet). Cut on water jet, quick spin on a lathe to put the required taper on the teeth.
                  Job done!
                  ― Hunter S. Thompson
                    Re: prop. What plastic is used (specifically) so that the tension strength can be calculated against centrifugal forces.
                    Jason Broadhurst
                      If ABS you are looking at roughly 20-40 MPa
                      What is the rough dimensions of a prop?
                      Jason Broadhurst
                        oh and rpm
                        Jason Broadhurst
                          Anywhere from ~50 mm to 50 metres.
                          oh and rpm
                          Anywhere from 30 rpm to 48,000 rpm.
                            Proportional dimensions wrt cross sectional area vs length.
                            rpm for a the plastic prop/engine it is fit to.
                            Ask a stupid question, get a stupid answerer
                            Jason Broadhurst
                              3D printed cast
                              http://mashable.com/2013/07/04/3d-printed-cast/
                              Originally posted by 50RTD
                                Been busy on the printer the last few days.
                                Got a job to print a small Wally Lewis statue, standing on a base. Should end up about 220 mm tall.
                                And also to print out six spotlight surrounds.
                                Sorry about the photos but the damn stuff just does not like being photographed.
                                I can chrome these things
                                Or any other stuff you print like badges etc
                                List of cars goes here
