    Okay I'll work out a price for all those for you.
    Any idea on pricing Bill?
      Fark I forgot .... working it out now.
        Wow that's a lot of stuff.
        Bed parts (4 parts) = 7g
        Bed carriage P2 + P3 parts = 54g
        Extruder housing = 22g
        Motor mount = 21g
        Rod support P1 (2) = 42g
        Rod support P2 (2) = 38g
        X-carriage (2) = 47g
        Z-carriage (2) = 38g
        269 grams x $0.50 (bulk rate) = $134.50 plus postage.
        That's with the parts having the thickest skins and most dense fill, I can trim a fair bit of the fill back if you like .... I'm pretty sure the parts would all be plenty strong enough even with a lot less fill.
        bed_carriage_p2_P-013.stl has a problem with the model, the software reckons there's 'no support' near the top of it, got another source for that part?
          Hm, it is quite a lot of stuff. Does this part work better: http://www.thingiverse.com/download:85922 for the p2_P-013?
            Weird .... yes & no.
            No in that if I orient it on the print platform the best way it's still got that error. but If I stand it upright (not the best way to print it) it says it's okay but only using 6g of plastic ..... which isn't right.
            I guess it'd print in the upright position but it would be much better if it were flat instead, which the software won't let me do.
              Sounds like a pain in the butt. Ill have to decide later whether i do this, or a Prusa. Im a bit of two minds.
                Originally posted by JamesB View Post
                The 3 print runs that I've done have used an estimated 100 ml of resin (25.7ml, 25.8ml and 41.8ml), so I'm becoming less worried about the cost of keeping the printer fed.
                OK, my calculated usage figures seem to tally well with the usage based on the tank volume. On their support forum, Form Labs has stated that the tank filled to the "Max Fill" line holds approx 200ml. After my 3 print runs, the resin tank is almost exactly half full.
                James
                  Hm. Looks like I can get the plastics for a Mendel for about $50 and it's relatively well supported with tons of mods. So I reckon I might do that one.
                    Ive ended up getting bits for a Prusa i3 EINSTEIN chassis fairly cheaply. Just need to get the plates laser cut now.
                      http://www.thingiverse.com/thing:114468
                        Anyone have the ability to print me up a couple of knobs for an old (30 odd years) Chef Glendale gas stove. Have a few that are still functional, but at least two are unserviceable. I imagine you'd be needing a file to print from, so, assuming nobody has one for the particular type of knobs needed here, can somebody work from a functional example, scan it then print copies?
                        Cheers, Richard
                        - Long Term Jobs
                          I don't have a scanner but if someone here can make a file I'll print them for you no probs.
                            Dunno how this stuff would go in your 3D thermal plotters out there, but,
                            The nopics does a lot of craft type shit, working with different media/materials, she has just had delivered a couple large jars of small plastic beads, each bead approx 3-4 mm diam.
                            You put them n water at 60 deg celsis, they melt down, you then mould it into whater shape, or use it as plastic repair etc.
                            Product is caloed
                            "Plastimake" website is platimake.com. Bloke here in aaus impirting the stuff.
                            Reckon f the 3d plotters work in a thermal heat up basis, maybe these beads can be run through it.
                            Any good?
                              Probably not sorry, certainly not for mine as it uses a 1.75 mm diameter ABS filament that looks a lot like a whipper snipper reel.
                                This just arrived for me, build thread coming soon
